eQSL mutilple calls uploads/download
#1 Posted : Tuesday, October 18, 2016 9:16:10 AM(UTC)
Was thanked: 68 time(s) in 61 post(s)
I started to use eQSL. I accidentally uploaded my entire log under one call sign. I've had 2 other calls in the past.
I followed the instructions on eQSL FAQ to delete my log and created 3 accounts with start and end dates for each call sign.
I don't have start and end dates in LOGic though.
Has anyone uploaded logs to eQSL with multiple calls? How do you do it?
#2 Posted : Tuesday, October 18, 2016 10:11:35 PM(UTC)
Was thanked: 504 time(s) in 418 post(s)
I'm not sure how they handle this, but I'm guessing that between the operator field and the QSO Date in LOGic, LoTW can figure it out. LOGic doesn't need to know about the date ranges.
Do you have a separate STATION LOCATION for each call in TrustedQSL, even though they are the same physical QTH? If so, you could export just one call, select the proper station location, and all should be good. Try this if just uploading it doesn't work.
#3 Posted : Tuesday, October 18, 2016 10:17:28 PM(UTC)
LoTW works just fine.
My problem is with eQSL.
I have 3 accounts in eQSL with 3 call signs. Each call sign has a start and end date (per eQSL instructions). When I upload my logs, I must be doing something wrong within LOGic because I uploaded my entire K1VC log to all 3 accounts.
Vin
#4 Posted : Wednesday, October 19, 2016 7:08:34 AM(UTC)
Was thanked: 124 time(s) in 111 post(s)
Just do an ADIF export for each of your callsigns, and upload the files separately.
WN4AZY on 10/19/2016(UTC)
#5 Posted : Wednesday, October 19, 2016 10:53:27 AM(UTC)
Thank you W5GA...off to read how to create and export ADIF in LOGic.
Vin
